Revision as of 23:24, 12 September 2019 by CT>Admin
http://copy.autofxpro.com/ ​​​​​ http://register.autofxpro.com/
This error was seen when the copier was not updated. Ensure that all of the URLs are put in (see COPIER NOT WORKING section). Ensure that AUTO TRADING is enabled. Please see the INSTALLATIONsection for additional information.
