Slippage determines how far away from price a position will open/close. This is based on the lowest value available for the chart you are on. If your chart is in PIPS then it will be different from POINTS or PIPETTES (same as TICKS). The default should be OK but modify as you wish. The image below shows what it would look like on a chart. You may zoom in for more details.
This section was messed up during the site migration. The images related have been lost and I can't recall which ones were here. Please refer to the images above.
Custom pair: Only copy trade of custom pair (combine with order types above). You can input multiple pairs by putting comma (,) or semicolon (;) between them. E.g: EURUSD; GBPUSD; USDJPY. You can also exclude the pairs by putting exclamation (!) in front of the pairs. E.g: !EURUSD; !GBPUSD; !USDJPY.
center|frame
If this does not work for you - then you may have to change the broker. Check your journal for any error messages.
