It's recommended that a VPS is used to prevent issues. If your VPS was pre-loaded with MT4, or if you want to setup your own MT4, download and install the appropriate version. center
The setup process is automated and you just need to click NEXT, but if you have multiple MT4 versions already installed (from the same broker) you will have to choose the folder by clicking on SETTINGS. center
left
center|frame
Once you’ve completed this hit NEXT and the install will go to completion. Once it’s done hit FINISH. center
Once you’ve logged in you can now open the web browser (IE, FireFox, Chrome, etc.) and log in to your email account. You should have a link to some files. Download the appropriate one for your MT4 installation. center
Your copy service provider may have given you a link to download the files - this can be from any source - Google Drive - DropBox - OneDrive - email - their own website - or a link to the original AutoFXPro site. Regardless, download the file that's appropriate for your installation. center center
Once you have this file downloaded, you will need to COPY the file. Do so by right-clicking and selecting COPY from the list of options. center
Once this is done, go back to your MT4/5 and open the data folder. To do this, go to FILE then OPEN DATA FOLDER. center
This will open an EXPLORER window to the data folder. You then need to navigate to MQL4\EXPERTS and paste the file. If you’re using MT5 the folder will be MQL5\EXPERTS. center center
Once in the EXPERTS folder you will RIGHT-CLICK and PASTE. center center
Click on the + beside EXPERT ADVISORS in the “Navigator” window to expand the view. Then RIGHT-CLICK on EXPERT ADVISORS and go to REFRESH. center
Once you do this the copier will show up in the list. If it doesn't, simply close your MT4 and open it after waiting a few seconds. center
Before adding the copier to the chart you must set some options first. Go to TOOLS/OPTIONS and then change these settings. center center
center
center
Once this is completed and you drag the copier back on the chart, it should look like the screen below. If not – maximize (make bigger) the chart you’re on. center
From here you click on PROVIDER LIST and add the numbers you received in the email. Add the number under ACCOUNT NUMBER and under DESCRIPTION you can add whatever you like – “Uncle Lee” for example. center
If you receive an error like the one below contact an admin in the group. This means that your account is not enabled on both sources as yet – you should wait for a confirmation email or message from an admin. If you received this confirmation but still get the error below then definitely contact an admin. center
Once this is done – set your risk management and then leave it to copy. The copier allows you to set various options and the PDF manual you received should go into enough detail on how to set this up. center
