1 – Provider Risk Scaling
2 – Multiplied By Provider’s Lot Size
3 – Ratio With Receiver’s Balance
4 – Fixed Lot Size
5 – Stop Loss Risk Percentage
This option changes based on the options you select. Examples (from an older version) can be seen below.
